engine stall
Old Apr 25, 2001 | 08:23 PM
firenut's Avatar
firenut
engine stall
Hello....
I'm not a very experienced machanic, and I have a little problem that has been bugging me for quite a while.
I have an 86 Ford F-150.
fuel injected, 8-cylinder 5.0/302
Here are the symptoms of the problem:
my truck stalls after it warms up. Every time I bring my truck to a stop, I have to keep a little pressure on the accelerator in order to keep it from stalling. The problem seems to get worse when I turn on the air conditioner. The problem seems to get better during the winter. In other words, when it is cooler outside, the truck doesn't seem to want to stall as often. When I turn on the heater, there doesn't seem to be any difference either way.
What I have done: 1) I replaced the EGR valve, I've replaced the PCV valve, I've replaced the vaccume lines, I've replaced the Air by-pass valve, I've replaces the TPS. It seemed to help when I had the fuel injectors cleaned, but not for long.
I'm at a loss, I'd appreciate any advice I can get.
Thanks
firenut
Old Apr 25, 2001 | 11:31 PM
sweet82's Avatar
sweet82
engine stall
my truck done the same thing I changed the plugs and wires
hasnt stalled since
Old Apr 26, 2001 | 12:11 AM
corlucci's Avatar
corlucci
engine stall
I had a car that did similar things as your truck once, it turned out the crank sensor was bad. The darn thing would go absolutely dead, and if you let it sit for a few minutes it would start and run for a while, then die again. Very frustrating. Anyway, just a thought.
Old Apr 26, 2001 | 05:04 PM
firenut's Avatar
firenut
engine stall
Thanks for the advice. The next two things I'm going to do is change the wires and plugs, and also change the sensor. I appreciate your responses. I'll keep you posted.
Old May 7, 2001 | 04:38 PM
be_likemike's Avatar
be_likemike
engine stall
Vacuum Leak? Does it idle with your foot off the brake? If so, you gotta vacuum leak.
Old May 7, 2001 | 08:02 PM
Pastmaster's Avatar
Pastmaster
engine stall
BradBryan58
Jan 17, 2015 07:47 AM
Duncansm
Oct 5, 2014 12:33 PM
BimmerM3_in_GA
Mar 4, 2008 10:37 AM
digitalbanzai
Jul 11, 2006 12:17 PM
MarkMc00
Bronco II
15
Feb 15, 2004 05:23 PM
