rear main seal
Old May 7, 2001 | 01:13 AM
toughf1's Avatar
toughf1
rear main seal
I had the motor in my truck replaced last september, it is a 302, now rear main seal seems to be leaking occasionally. It doesn't always leak, in fact i have only seen it once, but when i step on the gas, i smell oil, and my oil pressure has been going way down, and then back to normal lately. Is this common on 302's, and does it sound like a rear main seal since it only leaks occasionally. i have a short trail of oil down the back of my oil pan and it looks like it is coming from in between the motor and the tranny. Thanks for hte help.
-Shawn-
Old May 7, 2001 | 09:06 AM
Pastmaster's Avatar
Pastmaster
rear main seal
The rear main seal in my 93 F-150 302 is also leaking occasionally. Especially when I've ran it on the highway for periods of time. I still have yet to add any between changes. It's kinda expensive, so I wouldn't do anything till it runs out. MY 2 cents
Old May 7, 2001 | 08:39 PM
jakegypsum's Avatar
jakegypsum
rear main seal
Shawn, It does sound like a rear seal. Have you checked your oil pressure sending unit? I had a truck one time have the sending unit go bad. Not only did it give false and bogus readings, it also leaked big time. I am not sure where you sender is positioned but the one that I had was positioned in a way that the oil would travel to the rear of the engine before dripping to the ground. Just a thought. Good luck.
Jakegypsum // Ford fleet, soup to nuts.
Old May 7, 2001 | 09:34 PM
jbigger's Avatar
jbigger
rear main seal
