I didn't do for the mileage. The points needed replacing, so I went electronic. The wires/plugs were in support of the new ignition. The carb turned out to be next weakest link in the chain, so I replaced that too. The mileage increase was just a bonus.
This truck is not my daily driver, in fact, it barely gets started weekly. I use it maybe a couple hundred miles per month.
Go to my gallery to see what I have on my 390. My mileage didnt get much better, but I get to where I want to go faster. And when you pop the hood at the gas station, people tend to look in there. Just keep buying parts!
This will save u alittle gas & give u MorePower.If you have a good clean
cooling system go with a Electric cooling fan setup. Basically the fan is only needed in city driving..my 2cents
orich
If the truck is a keeper spend some money and get your new headers coated inside and out with a ceramic coating like HPC. This will keep the heat in the pipe and away from the engine compartment and starter. You will gain a few % in performance with the coating as will as extend the header life from rust out.
I went from 10 MPG to 14 MPG by simply "bolting on" the Edelbrock 1406 to my 390. Still using the old distributor....I have replaced the plugwires and have installed new NGK plugs. I bought my new carb from a local auto parts chain for about $300.
I added an "S" intake I bought for $50. I already had a very nice Motorcraft 4300 4V off a 1974 460 pickup. It runs better in the mid-range and at WOT. I am happy with the gain in performace for only adding a 4V carburetor. The truck already had dual exhaust.
I have no idea if it improved or hurt the gas mileage because I have only "roughly" checked the mileage one time and it was a little over 7 mpg. I had a little over 1200 pounds in the bed and was towing our 19' travel trailer loaded for camping for 4 days.
I haven't checked the mileage while empty and don't drive it enough to care but I can tell you it does like gas.
I changed a lot of stuff on my rebuilt 390 (list is in my gallery), so I ended up with a lot more power and the same mileage as my old motor with everything stock.
Carl....=o&o>....
I would like to add that getting the headers coated removes a great deal of heat from under the hood also. I can put my hands on my headers within a couple minutes of shutting the engine off on my blown 406. The starter is cool enough, you can lay your hand on it any time, but without the coating there was no way.
