Alternator question
Old Mar 17, 2005 | 08:05 AM
myke's Avatar
myke
Alternator question
Ok, I was getting the battery light at idle, with a real low needle on the ammeter. The alternator was under a lifetime warranty so I got a replacement (says rebuilt, but looks brand new). Now the ammeter needle is all the way to the right - not in the red, but on the line. I checked the voltage at the battery & I'm getting 17+ volts. Bad new alternator, or did I miss something? I noticed the small single plug on the top of the alternator didn't seem to fit real snugly. The tab which helps hold it on was broken off. - is that wire for the voltage regulator? It wasn't that hard to replace the alternator, but I'd just as soon not pull it again if I don't have to. Thanks for your help, guys.
Old Mar 17, 2005 | 09:51 AM
73Custom's Avatar
73Custom
What vehicle is this on? Does it have a seperate voltage regualtor? It's the voltage regulators job to tell the alt how much to charge...
Marty
Old Mar 17, 2005 | 11:09 AM
myke's Avatar
myke
It's actually on my wife's '94 T-Bird with 4.6 engine. I assume the regulator is internal.
Old Mar 17, 2005 | 01:07 PM
beartracks's Avatar
beartracks
17 is too much if it's accurate.
Old Mar 18, 2005 | 09:47 AM
Franklin2's Avatar
Franklin2
If that plug is loose, it could be the problem. The internal regulator monitors the system voltage through one of those small wires. If it's loose or a poor connection, then it thinks the system voltage is low, and cranks out too much power. Try squeezing the connectors together a little bit with a screwdriver to make them tight on the terminals.
