My first problem-Overheating
Old Mar 16, 2005 | 11:25 PM
zenitram's Avatar
zenitram
Sorry for the long post but i'm trying to explain:
I have about 12K miles (only modification is the Hog 4" cat back) and have had no problems so far, but lately I had been hearing a strange noise after acceleration, then.... The noise kind of sounded like waaaaaa. The sound started loud and then attenuated down. Each time it happened, it lasted about 3 seconds.
The noise went away so I figured that all was good. On the way back from pismo (pulling a trailer), the truck started overheating, and I experienced a reduction of power. I usually go about 55 MPH over cuesta grade, but I could barely go 35-40. The temp gage (gauge) was reading in the red and the check engine lighe was on. I reduced speed and the temp dropped a bit. I continued on and got home ok, but there were several times the temp gauge would shoot up and the (loud) engine fan turns on.
Now, my truck is overheating in the drive-thru, and in the morning, the engine fan starts up as I am leaving the driving away (and it's only about 45 degrees outside).
I'm taking it in friday, but do you have any ideas what it might be?
Old Mar 17, 2005 | 06:04 AM
SBV45's Avatar
SBV45
Check the coolant level. Make sure all the radiator and overflow caps are secure and check the security of the radiator and coolant hoses.
Old Mar 17, 2005 | 05:00 PM
zenitram's Avatar
zenitram
I checked the coolant, and everything under the hood including the under of the hood is white with the film of the coolant. Because of all this blown coolant, the resavore is empty.
No hoses or anything else seemed out of place.
Old Mar 17, 2005 | 05:53 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Might have blown a head gasket. do you see bubbling in the reservor? If you do, this is probably it, sorry to say.
Old Mar 17, 2005 | 07:20 PM
zenitram's Avatar
zenitram
Oh NO! Is that something that is common?
Old Mar 17, 2005 | 07:24 PM
GMCDrive's Avatar
GMCDrive
a blown head gasket should be covered under waranty shouldn't it?
Old Mar 17, 2005 | 07:25 PM
zenitram's Avatar
zenitram
Yes, but I was going to take my toy hauler to pismo for spring break!
Old Mar 17, 2005 | 08:41 PM
zenitram's Avatar
zenitram
There is one correction I need to make. I stated that the check engine light was on. That is the amber engine symbol on the bottm left of the cluster. I should have said that the check gage (red light in the top right of cluster) was on.
This was probably due to the high temp reading of the truck.
Does this change your oppinions?
Old Mar 17, 2005 | 09:55 PM
biz4two's Avatar
biz4two
Could be the water pump, thermostat, or the radiator cap. The radiator could be the cause too, but only if it is plugged and not flowing the coolant.
Where was the coolant coming out? The radiator cap? Or from the over flow bottle?
Also, before driving it again, I would top off the coolant level. Better safe than sorry.
Old Mar 17, 2005 | 10:14 PM
KnightRider's Avatar
KnightRider
I think it is because the 6.0 head gaskets are crap....
I am going to try head studs and new gaskets to fix the over-heating issues in my 04 with 62k.....
Old Mar 18, 2005 | 12:51 AM
zenitram's Avatar
zenitram
I just checked the coolant level, and it was bare! It took quite a bit to get it to the min fill line, and like I said, there is white film from the coolant all over the inside of the hood and motor.
Old Mar 18, 2005 | 04:44 AM
bigredtruckmi
Veteran: Navy
Take it back ASAP and don't load it. You could cause more damage!! Yes it will be covered under warranty if you have less than 100,000 miles.
Old Mar 18, 2005 | 10:40 AM
zenitram's Avatar
zenitram
I have about 12K miles on the truck so it is definitely under warranty. I am taking it in today and will let everyone know what they tell me.
Old Mar 18, 2005 | 06:44 PM
zenitram's Avatar
zenitram
I just got a call from the service department...Truck is done!
They said that the thermostat was sticking and the clutch on the fan was bad. We will see.
They say NO blown head gasket.
Old Mar 18, 2005 | 10:01 PM
biz4two's Avatar
biz4two
Good to hear it! You should be fine from this point forward.
