Dumb question
Old Mar 16, 2005 | 09:21 PM
shawn001's Avatar
shawn001
Dumb question
Gents,
Dumb question - what is the difference between a 1/2 ton and 1 ton etc ... ?
Old Mar 16, 2005 | 09:57 PM
300 4 ever's Avatar
300 4 ever
Pretty much its payload capacity. The higher the ...ton, the more heavy duty the whole truck is. The 1/2ton, 3/4ton, ... are a little misleading, I would say most trucks are good for another 500-1000 lbs beyond their rating, maybe a little more one way or the other, depending on their setup.
Old Mar 16, 2005 | 10:31 PM
shawn001's Avatar
shawn001
Thanks for the reply... So, what would a basic say mid 80's F-150 single cab short box 4X4 be rated as or, does it depend on things like suspension and tire package etc ?
Old Mar 16, 2005 | 11:06 PM
300 4 ever's Avatar
300 4 ever
Take a look at your sticker in the door jam. It should give you a GVWR number. Take that number minus your vehicle weight and the will be close to your recommended max. That truck probably weighs about 4200-4500lbs. Its ok to exceed the max GVWR, but to an extent as that can become dangerous.
Old Mar 17, 2005 | 12:22 AM
midlf's Avatar
midlf
You also need to pay attention to the axle weights. It is possible, but not easy, to be within GVWR but overload the axle rating. Also the ratings are only good with the tires listed. For instance my truck is listed as 8600 GVWR but the tires are only rated at 2000lb each giving me a max for the truck of 8000lb. That is IF I can get the load to balance at 4000lb at each end.
Old Mar 17, 2005 | 10:16 AM
MemOrex's Avatar
MemOrex
I thought you could just say:
F-150= 1/2 Ton
F-250= 3/4 Ton
F-350= 1 Ton
Old Mar 17, 2005 | 10:39 AM
qman's Avatar
qman
The higher the tonage the more heavy duty the axle, springs, etc. You also start seeing high capacity tires on the higher tonage vehicles also.
