need speedo help please
"Locate the dealer mode programming enable single-terminal connector. The connector is located at the bottom of the instrument panel below the center of the glove box. On all vehicles, the dealer mode enable wire is Circuit #567 (LB/Y).
Insert metal clip in service wire panel connector. Clip other end to vehicle ground while the key is in the OFF position"
what kind of metal clip do i need? where is the circut at, what does it look like?
thanks for any help
