My axles are Superior...
No, really
Dana 60 Superior 4340 chromoly axles, the strongest readily available. 35 spline inners and outers. Used with CTM's, naturally. Heres your teaser pic:
https://www.ford-trucks.com/user_gal...oid=72034&.jpg
Some have been curious why I would spend the mad amount of $$$ on Superiors, when you can get other moly axles (such as yukons) for much less. In these pics, you can see why:
https://www.ford-trucks.com/user_gal...&albumid=15391
The Superiors have improved and seriously beefed the area around the ear. This is the weak spot in any d60 35 spline axle. Its compared next to the stock spicer which is identicle to the yukon in dimensions. Also, quality control of these pieces are immaculate whereas with their competitors variations in ear thickness have been measured up to .10 +/- (per Billavista).
I don't need to say how much I'm impressed with these axles as well as the CTM's. Talk about well-matched parts...I don't think these pieces will be the next things I break
Nice. I toy with a superior 44 kit, but since nothing is broke, Why If (and that is a big IF) I ever step up to 44s, my plan is rockwells and tractor tires None of the breakage, all the traction. The attraction for me is that 2.5 tons are cheaper than swapping in 60s or 70s and upgrading them. However, the way I flog my 300 with the top 1/4" of the throttle, I think my 44/ 60 combo should last for a few more outings
You know Pro, we'll probably be regretting not buying the new 40 spline junk in no time flat. Question for you: I know we talked about painting these shafts and Billa's article recommended some special acid etch primer that should be used first. Have you managed to find this primer anywhere? I want to hit up my shafts with it before they go in the truck. Otherwise I'll clear coat them to keep the bling effect.
I've got a tracking number on CTM's now. The suspense is killing me! Not that I have the rest of the junk I need anyway. Besides all the parts I'm waiting on my grinder died about 2 minutes after I got off the phone with you last night. So I had to scrap turning the perches. Hit up Lowe's at 6AM and bought a CHEAP one this morning. We'll see if it lasts longer than that damn Porter Cable.
I burned up the Milwaulkee last year on misc junk before I even started tearing into my suspension. If I remember correctly it died when I was shaving my rear axle. I chopped about 3/4" off with the sawzall (Milwaulkee) and then went to work with the grinder. Bearings toasted all to hell, it seized up, and burnt out the winding. That's why I bought the PC but the top bearing in it died last night. The rest of it is good though so I may see if I can get that bearing replaced. In the mean time it's a $40 Firestorm POS. If it can last me 4 weeks I'll be happy. I have the pneumatic setup but my compressor can't keep up.
I haven't broken anything yet but I was in the process of tearing my D60 apart to turn the knuckles. I found I had a dying U-joint and figured while I was replacing it I should upgrade the axles too. So dip there starts blabbing about Superiors and CTM's and I had to buy them too, though I'm not going with Superior inners just yet.
If an outer stub breaks or U-joint breaks it'll often toast the ears on the inner shaft. But if an inner breaks there's no harm done to the U-joint or outer stub. So I'll run the Spicer inners for as long as I can. I did upgrade to a non-neck down set of inners though, since it was cheap. Pro's damage all occurred because he broke an outer stub which caught and broke his U-joint which stretched the ear on his inner shaft. Of course this is all because he couldn't steer. "I just really don't see the need for hydro assist on a mud bogger." I think if the outers and u-joints are indestructable it's going to be HARD to break an inner shaft.
