overdrive, or not?
Old Mar 16, 2005 | 08:25 PM
captchad1's Avatar
captchad1
overdrive, or not?
I was reading in the forum on the Escapes, and saw someone said when driving below speeds of 45, turn off the overdrive to save the torque converter. Should we turn off OD in our Explorers with the 5 speed automatic? If so, at what speed?
Old Mar 16, 2005 | 08:58 PM
KawiG5's Avatar
KawiG5
I never turn off the OD on my Explorer. Never had any problems. My dad has a 1995 Bronco and he always leaves the OD on as well.
Old Mar 17, 2005 | 05:22 AM
marragtop's Avatar
marragtop
I agree, no need to turn OD off. One exception is if you are driving in the snow.... however, you probably won't be going fast enough for it to kick in anyway...
Old Mar 17, 2005 | 05:09 PM
JerrySimm's Avatar
JerrySimm
Only other time I turn it off is if I'm going down a steep winding grade. I use the transmission to downshift and slow the car, and turning off the OD prevents accidentally slamming down 2 gears. I do the same thing in my '96 350.
Old Mar 18, 2005 | 10:01 AM
captchad1's Avatar
captchad1
thanks for the feed back
Old Mar 18, 2005 | 11:13 AM
Pete Johnson's Avatar
Pete Johnson
I find that using OD in normal traffic, or city driving is what it was designed for. It provides a gear that will let the engine run at a lower rpm. I use mine when comming down steep grades ( acting like a brake ) and going up hill's so not to slow like a semi truck.
