Bronco II Ford Bronco II
BII problems
Old Mar 16, 2005 | 08:12 PM
rknott's Avatar
rknott
BII problems
I have a 1988 Bronco II, 2.9 liter, automatic with Touch Drive 4WD. It has automatic locking hubs. My problem is when I try to shift into 4WD I can hear the solenoids working and the shift motor trying to operate but it will not engage the transfer case. The funny thing is it works fine in the summer or when it is warm weather. It will not work in cold weather. Another problem I'm having is my gas mileage has dropped dramatically. It went from 17 to 12. If I don't let it get to at least 140 degrees before trying to drive it, it will cut off and is almost impossible to start. I need some pointers please.
Old Mar 17, 2005 | 10:48 AM
mrshorty's Avatar
mrshorty
Your 4WD problem sounds to me like the shift motor is dirty. Quite common, and can easily be dissassembled and cleaned out.
As for the gas mileage drop, the first thing to do would be to pull codes from the computer. See Ken00's tech info post for instructions (only requires a paper clip).
What's this about it stalling if you try to drive it cold? That could be a dirty throttle body/intake. Could also be a bad O2 sensor or other part of the engine management system. Again, start by pulling codes.
bam5464
Dec 5, 2014 07:27 AM
RJK671
Nov 8, 2013 05:32 PM
bigkeeser
Apr 13, 2012 12:23 PM
c-bolt
Mar 30, 2009 06:05 PM
XXL Supreme
Jun 30, 2007 05:21 PM
