Electrical problems when raining
Old Mar 16, 2005 | 04:27 PM
millerman's Avatar
millerman
Thumbs down Electrical problems when raining
Ocasionally in a heavy rain my Expedition will have transmission problems. It will either simpley act like it is in neutral or it will not shift out of low gear even though it is in the drive position. Next the dash lights will start blinking and the overdrive on/off button light on the shifter will blink on and off.
After the vehicle ''dries out'' the tranny and light will work fine except for the air-bag light stays on. I know this sounds like an electrical problem, but does anyone know where to start?
Old Mar 16, 2005 | 05:26 PM
Monsta's Avatar
Monsta
Sit. Stay.
What year?
Older Expys and F-150 were known for a leaking windshield that dripped water on the ECM causing all kinds of weird electrical problems.
Hopefully, someone who has had the problem will chime in.
Welcome to FTE, millerman! Glad to have you aboard!
Old Mar 16, 2005 | 06:08 PM
millerman's Avatar
millerman
1997 Expy. EB Edition. The air-bag light flashes 5-2. My speedo does not work either.
Old Mar 16, 2005 | 08:40 PM
saltzy's Avatar
saltzy
Sounds like the GEM module is getting wet to me. I had the same exact symptoms, although it's been several weeks since it cropped up. I have purchased a new GEM from Ford (~$250) but have not yet installed it since the old one is again working once it dried out.
BTW, this is typically, as said above, from a leak at the windshield letting water down to the GEM/Fuse box area. I never had this problem in the 4 years I've owned my truck until I had the windshield replaced last fall by Giant Glass. They've been back to reseal it once already because water was actually coming into the cabin up from under the glass and splashing me while driving... I'm sure your leak is nothing like that, but still a few drips into the GEM is all it takes.
Old Mar 17, 2005 | 07:37 AM
ugotkern's Avatar
ugotkern
Definately leaking windshield.... I have a 1998 Expedition Eddie Bauer and after each heavy rain storm I would have several differant electrical problems. I had my windshield replaced and all the issues went away. The only issue that stayed for about a month then just disappeared was my airbag light stayed on. Happy to say $200 for a new windshield fixed every electrical issue and I didnt have to replace the GEM module.
Old Mar 17, 2005 | 02:02 PM
Monsta's Avatar
Monsta
Sit. Stay.
Sorry...I shoulda said GEM but instead I said ECM. I just replaced my ECM (or PCM) on my van and the "wording" was fresh in my mind. .
Old Mar 18, 2005 | 08:33 PM
millerman's Avatar
millerman
Thanks to all for the info. I checked some fuses and three were blown. I replaced two and everything was fine, but when I replaced the third the fuse box sparked up like the 4th of July! To the Ford service folks we go!!!! New GEM module, fuse box, new seal for the windshield, and 8 bills later----I'm back on the road. Thanks for the input. The info. was right on the money!
Andy's Beast
25
Mar 3, 2020 01:44 PM
TX92F150
Aug 8, 2013 08:32 PM
mikersix
Oct 28, 2010 10:38 PM
eehoepp
Aerostar
Apr 27, 2007 02:15 PM
cipher
Nov 8, 2003 06:02 PM
