CD Burner Problems
Old Mar 16, 2005 | 01:18 AM
rshissler's Avatar
rshissler
CD Burner Problems
Well i reinstalled my girl's computer for her after a massive spyware attack on it. I used the system restore that was already on the computer. Now when she tries to burn a cd it wont burn it. tells us that the CD isn't in the drive. I tracked it down to that its reading the DVD drive as the cd burner but it wont let me change the drives to it reads the right one. i tried download other burnin programs and stuff dont it dont work and i tried installed the drvies for it from the computers web site. It's a Dell Persario 735??? i believe if im wrong ill fix it later. anyone know how to fix this problem
Old Mar 16, 2005 | 07:17 AM
Huntsman's Avatar
Huntsman
Have you tried going to the control panel/system/device manager/click on the cd drive and remove it...re-boot and reinstall the drive and burner software?
Old Mar 16, 2005 | 08:18 AM
mikebon08's Avatar
mikebon08
Was the CD writer part of the original computer or did you/she/someone put it in later? If it was added later, the system restore won't have the right software for the writer. Otherwise, most software has a setting to choose recorder, which would normally let you choose either a cd-writer or an image file on the hard drive. Other possibility is that the writer isn't working right.
Old Mar 16, 2005 | 01:31 PM
rshissler's Avatar
rshissler
yes it came with the computer and it worked fine before i reinstalled the OS
Old Mar 16, 2005 | 01:36 PM
pfogle's Avatar
pfogle
What software is it? In the settings for the program you can change the burner. I know that with nero it's right on the page that you burn with.
Old Mar 16, 2005 | 08:25 PM
rebocardo's Avatar
rebocardo
If you installed Real Player, the Roxio drivers probably nuked the Roxio driver that came with your burner and messed up the registry. About the only solution they offer is to sell you their newest software for $80+ !
Old Mar 16, 2005 | 11:29 PM
rshissler's Avatar
rshissler
at first i was just usin the burnin thing that came with the computer. then i tried some kind of other burnin software i had and it still doesn't work. i tried deletin the drive and installin the software again and now it reads the right drive but the drive doesn't read the cd seems like the drive doesn't even move at all. i tried updatin the driver and stuff
Old Mar 16, 2005 | 11:32 PM
I6power's Avatar
I6power
im 99% positive its software
Nitramjr
13
Feb 28, 2007 11:31 AM
taisa899
Feb 19, 2007 11:13 PM
Brian_B
Sep 12, 2006 06:05 AM
z 97ford1
13
Jan 22, 2006 11:06 AM
rhw
Sep 28, 2005 06:32 PM
