King Pin Bearings
Old Mar 15, 2005 | 08:38 PM
TremecGT's Avatar
TremecGT
King Pin Bearings
Where can I find the king pin bearings? Mine dont even move anymore and I couldnt find them from the parts stores or LMC. My truck is a 65 F-100
Old Mar 16, 2005 | 07:43 AM
cdherman's Avatar
cdherman
They come with new sets of king pins and bushings. I don't think you can get them alone.
Old Mar 16, 2005 | 11:56 AM
barry's Avatar
barry
If the bearing are not moving, replace the king pins.They're probably toast by now. CD's correct, they are not a separate item.
Barry
Old Mar 16, 2005 | 02:01 PM
TremecGT's Avatar
TremecGT
That sux, my king pins are perfect. Anyone have a good used set?
Old Mar 16, 2005 | 02:58 PM
barry's Avatar
barry
I want to make a correction to my last reply. Yes, you can get them separate. I never stocked them and I never worked at any dealer that did. Anyway, it's part number C8TZ 3123-C or industry bearing number BE-87. I found some Ford ones on-line.
Wesley Obs. Liberty, Ky 1-606- 787-5293 Qty 2 in stock
Dale King Obs. Liberty, Ky 1-877-246-1111 Qty 2
Green Sales Cinci, Oh. 1-800-543-4959 Qty 9
Call them up and see. They'll give you price and shipping.
Barry
Old Mar 16, 2005 | 04:37 PM
TremecGT's Avatar
TremecGT
Thanx a ton, ll give them a try
Old Mar 16, 2005 | 05:44 PM
kotzy's Avatar
kotzy
I think you need to explain the statement they don't move. Do you have the vehicle
jacked up when your trying to move them? The weight of the truck rides on the bearings when the wheels are on the ground. The other thing is you may not be able to see the lower inner cover move as the top side kind of overlaps it. What I'm trying to get at is unlesss you have hard steering or erratic steering you may not have a problem. They fit in the space between the axle and spindle with only a few thousands clearance if you jack up the unit and get the weight off the bearing you may be able
to turn it or have someone else move the wheel in and out and see if it moves.
Old Mar 17, 2005 | 10:05 PM
TremecGT's Avatar
TremecGT
Well, I have the king pin bearings out now and I can not turn one by hand but the other side moves, although not very smoothly. The truck steered great before teardown. I plan on reusing my old king pins as they have no rust/pits and the bronze bushings in my spindles look brand new. When I mocked them up there was no play at all between the axle and spindle.
lets7777
Mar 4, 2012 10:01 PM
Sam_Fear
Jun 1, 2009 06:53 PM
Eric1966
Offroad & 4x4
Apr 6, 2006 02:34 PM
kjett
19
Nov 20, 2003 08:28 PM
Mark47025
Oct 29, 2002 01:31 PM
