No Ignition
Old Mar 15, 2005 | 05:22 PM
VENADO VIEJO's Avatar
VENADO VIEJO
No Ignition
i have a problem with my 1987 ford f-150 i cant start the motor and the motor gives a gasoline smell which could be the problem or what should i start checking
Old Mar 15, 2005 | 06:04 PM
xltlariat87's Avatar
xltlariat87
does the engine turn over at all. as for the gas smell the engine may be flooded.
Old Mar 15, 2005 | 06:06 PM
mantta's Avatar
mantta
If it cranks over and you are getting fuel, it is more than likely a TFI module gone south.
Old Mar 15, 2005 | 06:15 PM
MemOrex's Avatar
MemOrex
The coil is a possible culprit.
Old Mar 15, 2005 | 06:18 PM
xltlariat87
check for spark at the plugs,also check for codes.
Old Mar 16, 2005 | 12:58 PM
VENADO VIEJO
4x4 standard 5.0 i have spark,i disconected a spark and grouded the cable i reconected again and it started but the motor does not run still its kind of un-stabble also i took a spark plug out and it had crude gasoline,do you think the fuel injectors can be dirtty and not closing at time when the engine is shutt off cousing that the truck cant be restartted quickly and i have to wait about 40 minutes to restart the truck ????
Old Mar 16, 2005 | 09:11 PM
MemOrex's Avatar
MemOrex
Dirt, stuck injectors are a possibility. Another thing you might check is the Fuel Pressure Regulator. It might be bad, letting too much gas through.
Old Mar 18, 2005 | 11:10 AM
VENADO VIEJO
where is the gas pressure regulator located ????
Old Mar 18, 2005 | 06:20 PM
MemOrex's Avatar
MemOrex
If your '87 is like my '93, it should be in the back, right side of the engine. It looks like this:
Pull the vacuum line that goes on it, and see if there's fuel in there.
Old Mar 22, 2005 | 08:53 AM
VENADO VIEJO
thanks so much for your help guys,the main problem was that scince i use this truck just for the deer hunting season the return fuel line was hitted with a rock or mesquite branch and was completley closed not letting the gas to return freely and flodding the engine. MAYBE IN THE NEAR FUTURE SOME ONE HAS THE SAME PROBLEM AND THIS COMMENT CAN HELP.
and the last cuestion,i know in this truck i have to disconect something to TIME the motor what is this thing and where is this thing located ????????
thanks again
Old Mar 22, 2005 | 12:34 PM
guzzler96's Avatar
guzzler96
Lightbulb
On most it's called a SPOUT (Spark Output) connector and is located very near the distributor. It could be grey or black, mines grey and when unplugged the computer does not interfere with timing. It is more than likely a plastic jumper plug that jumpers two wires.
