erratic speedometer, strange take-off
Old May 23, 2001 | 06:29 PM
campbell2
Guest
Posts: n/a
OK guys, here's a good troubleshooting exercise:
I have a 95 F150 2WD, with the 4.9L 6 cyl. Speedometer is very erratic past approx. 40 MPH, (spiking 20-30 MPH!) and the engine tries to die out and then comes back on take-off (manual tranny).
Also wants to die when coming to a complete stop, just like on take-off.
Self testing shows error code 212 relating to engine TACH signal or SPOUT circuit. So far, i have replaced: TPS, RABS speed sensor, Ignition Module, and tested the coil.
The really fun part is: if I unplug the RABS speed sensor completely, the truck runs fine.
I'm currently looking for directions to test the SPOUT circuit or any other (related) ideas - I have about driven myself nuts trying to troubleshoot this. Any suggestions would be greatly appreciated!
Old May 24, 2001 | 12:21 AM
CantDrive55's Avatar
CantDrive55
Do you have cruise control? It could be kicking on somehow, pulling on your throttle erratically. It's just a wild guess. You could disconnect the cruise cable from the throttle cable, and see that gets it. Just an idea...
Old May 24, 2001 | 12:35 AM
canadianfordman's Avatar
canadianfordman
Old Sep 10, 2007 | 11:44 AM
hansosc's Avatar
hansosc
campbell2 -if you find out what's causing this please let me know, I have the same problem and when I remove the speedometer fuse the truck runs fine.
Steve
Old Sep 10, 2007 | 01:32 PM
Franklin2's Avatar
Franklin2
You may have problems in the rearend, causing metal shavings to get stuck to the sensor. Pull it out and look at it. Also check the wiring for corrosion at the sensor.
Code 212 does have something to do with the dist though. I would check the wiring at the dist. One of those wires has a shield, and it can get against the signal wires.
Old Sep 10, 2007 | 01:54 PM
hansosc's Avatar
hansosc
Franklin2 -Thanks for the reply however that was campbell2 that had the code 212 error. The chaeck engine light has never come on so I assume that mine dosn't have any error codes, I will check that ABS/Speed Sensor for metal shavings and clean it see if that helps. Thanks
