MSD 6a effects
Old May 17, 2001 | 08:37 PM
xaviar's Avatar
xaviar
MSD 6a effects
Thanks for the web site Silk. Heard much about side gapping plugs but never seen the info.
Thx again.
Xaviar
96 F-250HD 4x4 460/E4OD 4.10
Banks Power Pack, Banks Trans Command
MSD 8227 Coil, MSD 32199 8.5 Wires, MSD 6A
Old May 18, 2001 | 10:48 AM
bjoern's Avatar
bjoern
MSD 6a effects
Note that the Bosch +4 plugs have that feature (side gap) already in the design (that's why I have them).
1988 F-150, V8, 5.0L (302ci), 5spd, SuperCab. Shorty headers, K&N filter, MSD 6a ignition, Accel 300 8.8mm race wires, Accel supercoil, Accel rotor+cap, Bosch +4 Platinum plugs, RanchHand bumper. Soon: Dual exhaust.
http://brembs.net/cars/FordPU.html
Old May 18, 2001 | 12:09 PM
Mtn. Scott's Avatar
Mtn. Scott
MSD 6a effects
Hey, bjoern: Have you noticed any problems with the Bosch +4's? The manufacturers and others claim that the platinum plug is not recomended for such systems. Any input on your experience would be greatly appreciated. Thanks!
Scott
1989 F250 4X4 Supercab
351w
Old May 18, 2001 | 01:03 PM
bjoern's Avatar
bjoern
MSD 6a effects
[font size="1" color="#FF0000"]LAST EDITED ON 18-May-01 AT 02:04 PM (EST)[/font][p]I've heard about those problems and wonder why I don't notice anything. I've put the plugs in before I did the other mods. I usually don't drive the truck longer than about 30 minutes and I don't haul any heavy loads. They work just fine for me (since about 1 or 2k miles).
Old May 18, 2001 | 11:25 PM
slikness's Avatar
slikness
MSD 6a effects
I've run platinum plugs with my MSD ignition and I'm not real pleased with their performance. I get an ignition miss under heavy load (towing) from stop once the engine is warm. I'm not sure if it is a plug wire or the plug itself, but I intend on changing both as soon as I get the chance. From what I read, the platinum plugs are built to retain heat as an intrinsic part of their design. The hotter spark of the MSD or Jacobs tends to melt the plugs down quicker than a normal plug.
'82 F150 2WD w/351W (orig 300 I6)
Slik
Old May 20, 2001 | 09:25 AM
Mtn. Scott's Avatar
Mtn. Scott
MSD 6a effects
Slik: Thanks for the input. It looks like bjoern's light driving explains why he hasn't had any problems. I've got my MSD parts in hand and can't wait to get 'em installed. The guy at my local parts store sold me a set of "Rapidfire" plugs--ACDelco. These are non-platinum plugs that he claimed were better. Did I make a mistake? They didn't have the NGK's, but I could take them back and exchange for Motorcraft. Also, you mentioned an extra .005 on the gap. I presume you have found this to be optimal for your rig. I also have the 351w and leave a camper (about 1500lbs) constantly on the truck. I have stock exhaust now but will soon have a performance system.
By the way, I got my MSD6a for $131.00 at Summit Racing--the best price I could find. Truck Performance.com had it for $50 more!
Any words of wisdom would be great. Thanks
Scott
1989 F250 s/c 4X4
351w
Old May 21, 2001 | 09:29 AM
bjoern's Avatar
bjoern
MSD 6a effects
Carparts.com sells the MSD at $117 with the 30$ rebate...
Old May 21, 2001 | 10:23 AM
Franklin2's Avatar
Franklin2
MSD 6a effects
Guide me through how to get that price. This is all I could find at Carparts.com
Manufacturer: MSD Ignition
* Prices are quoted in U.S Currency.
Product Description Glossary
Part Number Unit Quantity Your Price Qty Add to Cart
6A Ignition Control , Operating voltage: +10-18v DC; negative ground, current requirements: 5 amps-5,000 rpm, 10 amps-10,000 rpm, rpm range: 15,000 rpm with 14.4 volts, spark series duration: 20 crankshaft rotation, energy output max: 105-115 mJ per spark
• Usually in stock and available to ship within 2 business days. 6200 Each $159.95
Old May 27, 2001 | 01:31 PM
bjoern's Avatar
bjoern
MSD 6a effects
Alright, my final post to this thread. It seems my gasmileage increase has leveled off at/around 17/17.5 mpg mixed driving with A/C. That is a increase of about 2mpg from 15.5mpg without A/C. If you account 1mpg for the A/C the MSD 6a upgrade has given me 3mpg gasmileage increase.
Old May 27, 2001 | 02:02 PM
jethro's Avatar
jethro
MSD 6a effects
bjoern
15
Nov 14, 2022 09:44 AM
bjoern
May 7, 2022 02:58 PM
WyoExplorer
24
Mar 17, 2010 09:42 PM
je250ff
Oct 1, 2003 11:37 PM
bjoern
May 9, 2001 08:44 PM
