ford never fixed plug blow out!!!!!!!!!!
Old Mar 14, 2005 | 08:26 PM
JF5speed's Avatar
JF5speed
I just got off the phone with autozone and they checked and the 5.4 calles for the same pluge from 98 -up, they dont list motocraft in 05 but its the same champion plug as earlyer, so if it ever got more threads in the head it would need a longer plug right???
Old Mar 14, 2005 | 09:01 PM
triton_2002's Avatar
triton_2002
I don't think so. Take a look at this site:
http://home.comcast.net/~therazy/PIHeadSwapPage.html
It has a comparison shot between the non-PI and PI heads. It doesn't apprear to move the location of the plug, just has more threads. The PI heads also add about 40 HP, if I remember correctly.
Old Mar 14, 2005 | 09:13 PM
LxMan1's Avatar
LxMan1
The 04-05 3V head has a totally different plug with 3 times the threads of the 2V heads.
Old Mar 15, 2005 | 08:01 AM
MBDiagMan's Avatar
MBDiagMan
First of all just because Autozone shows the same plugs, that means nothing. It sounds like they don't sell Motorcraft plugs.
Secondly the PI heads and Intake add between 25 and 30 horsepower according to Sean Hylands excellent 4.6 Ford Engine book.
I would suggest that you read the spark plug thread at the top of the 1997 to 2003 forum for plug information.
Good luck,
Doc
Old Mar 16, 2005 | 07:41 PM
2000BLK54's Avatar
2000BLK54
Ford did fix the problem....but not until 2003 MY. If you go to a shop that sells Motorcraft parts or to a Ford dealership (not much difference in price anyway) you'll find they have 2 PN's for the plugs. Either start with AWSF-XXX or AGSF-XXX. You can use AGSF plugs in any Modular engine...you'll just be using the bottom portion of the threads. Use the AWSF in heads that require the AGSF and you'll tear up the threads in the head because you'll be inserting the unthreaded part of the plug before the seat into the threads in the head...effectively ruining them.
Old Mar 18, 2005 | 12:34 AM
shapel's Avatar
shapel
Why can't a person use a helicoil on the damaged sparkplug hole? Helicoil makes a helicoil for sparkplug holes....
Old Mar 18, 2005 | 11:17 AM
2000BLK54's Avatar
2000BLK54
You could....but Time makes a specific kit for this issue and I think it's the best way to fix this problem as you don't have to remove the heads and the repair is permanen. Also allows for the useage of the fully threaded plugs.
Old Mar 18, 2005 | 07:03 PM
jeh250's Avatar
jeh250
Timesert
Here you go: http://www.timesert.com/
Old Mar 21, 2005 | 05:46 PM
kb-65's Avatar
kb-65
If you ust the heilcoil there wiil be no seat left for the plug to seat. heilcoil tap is larger than plug seat. use the timesert it works
Old Mar 27, 2005 | 08:15 PM
Big D 2's Avatar
Big D 2
I had a plug blow out of my head and it cost me $1200 to fix the head!!!
Old Apr 7, 2005 | 02:14 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
They fixed it.
Believe me.
The same sparkplugs can be used thats all.
Old Apr 8, 2005 | 05:57 AM
kb-65's Avatar
kb-65
BigF350, When did they fix this problem.
Old Apr 8, 2005 | 05:24 PM
BigF350's Avatar
BigF350
FTE Emeritus
November 14th 2002.
Old May 11, 2005 | 06:29 PM
chperry's Avatar
chperry
BigF350, I have an 03 F150 with 5.4L. How can I tell if mine has the new heads? I bought the truck in Feb. of 04.
Old May 12, 2005 | 01:30 AM
BigF350's Avatar
BigF350
FTE Emeritus
Do you know the build date?
It should be stamped below the VIN plate under the hood.
If it is after Nov 14th 2002, then you will have the 8 thread heads, otherwise you will have the 4 thread heads.
