Sponsored by: Auxito
Superchips Programmer model 1715
Old Mar 14, 2005 | 06:19 PM
stang3O2's Avatar
stang3O2
I know this model programmer changes the speedometer for changes in tire and wheel size, but does anyone know if this in turn will adjust the odometer to be more accurate and exact with the change in tire size?
Old Mar 15, 2005 | 12:16 AM
SHUSTANG's Avatar
SHUSTANG
if speedo is right then odometer should follow. i thought they were linked. i checked mine with gps and mile markers on interstate. yes i have the 1715.
Old Mar 16, 2005 | 03:14 PM
stang3O2's Avatar
stang3O2
Thanks SHUSTANG, I just bought one myself but I am picking it up today or tomorrow and I was curious on that!
Old Mar 24, 2005 | 08:38 PM
BEAL73's Avatar
BEAL73
I'm also curious. How much will it change the speedo? Can you put your own settings in or do you have to follow a set of choices? Like I have 31 inch tires with a 3.55 gear blah blah... The reason I'm asking, my speedo is about 30% off from a tranny swap. Will it cover this without an "out of range" error? Thanks
Old Mar 25, 2005 | 04:48 AM
SHUSTANG's Avatar
SHUSTANG
if the gear choice doesnt do it exactly , you can adjust by using tire size. you need to actually measure your tire. not all 31's are 31's. the superchips goes in 1/4" increments form 24" to 38" so setting speedo could pretty much be accurate. so yeah this should fix the problem but only if you have a 99 and up. 97 and 98 need a device just for calibrating speedo.
Old Mar 25, 2005 | 01:25 PM
BEAL73's Avatar
BEAL73
I have a 2001 with a digital odometer. Thanks for your help.
cdrmotorsports
Feb 5, 2016 10:48 AM
Watcher58
Feb 2, 2015 08:05 PM
Carnivore
2004 - 2008 F150
19
Dec 21, 2008 11:50 AM
1968stepside
1997 - 2003 F150
Feb 11, 2004 05:35 PM
