transfer case rebuild?
Old May 27, 2001 | 07:45 PM
nmaineron's Avatar
nmaineron
Is it better to rebuild a transfer case or should I heave it and
try to get another one.Mine is an 88 F250 auto and I have a clunk that is consistant in bull low,seems to be alright in 4HI.What can I put in there and what should I pay?Thanks Ron
Old May 28, 2001 | 09:16 PM
mjb1962's Avatar
mjb1962
You probably have a Borg Warner 1356 case. You can find them new for $1000. I purchased one from 4xheaven (www.4xheaven.com) in NY state and had it shipped to my residence.
Mark
Old May 31, 2001 | 02:09 PM
rocky's Avatar
rocky
I think I'd try to rebuild it myself. I've done a couple of transfer cases with my wife. {Her memory is better than mine.} Nowadays I take pictures along the way with a computer camera (no film needed.) The last transmission we did was a 727 Dodge, and my buddy had bought a how-to video. I think it was an EXCELLENT video, and well worth the price. I don't know if they make one for your particular transfer case, but if they do, you will see how really easy it is. I was scared of transmissions before, but now I'd jump right in. They even show you how to improve your transmission along the way. Just make sure you have a long bench with a clean white sheet on it so you can keep track of things.
Old May 31, 2001 | 04:12 PM
Eddie's Avatar
Eddie
I'd overhaul it myself.
Contact: Mike P.@standardtransmissions.com for good parts pricing and hand-holding, and get some sort of Ford or B-W shop manual. T-cases just aren't that complicated.
Apples-and-oranges, I know, but I just did a NP205 myself, using photocopies I made at the downtown library from old factory service manuals. Stuck the photocopies in plastic protectors, and those in a three ring binder--who cares about greasy fingerprints? They wipe off!
Eddie
Old May 31, 2001 | 08:55 PM
nmaineron's Avatar
nmaineron
Thanks guys,I am definately going to rebuild my Transfer case.I spoke with a fella who has a tranny shop that collects up as much stuff as he can and says that he has loads of good parts for my case.He is a good honest man and he says that I can get out of it quite reasonably.Thanks again, Ron
Old May 31, 2001 | 09:52 PM
fatforty's Avatar
fatforty
Hi, it depends on how the driveshaft is hooked to the transfer case as to which case you have if it slips in like a normal driveshaft in a trans then you have the borg warner if it bolts on like the driveshaft to the rear then it is a new process there should be a tag on it somewhere to tell you what it is if it is a new process the tag is right along side the driveshaft on the drivers side of the truck and it will have a number with the name my F250 has a new process 208. John
Old May 31, 2001 | 10:01 PM
fatforty's Avatar
fatforty
Arizona97
Mar 18, 2017 06:37 PM
JUSTICE1736
17
Oct 16, 2015 03:46 PM
mr.noodi
Jul 30, 2015 06:19 PM
bradf350
Jan 11, 2013 02:07 PM
Peter Richards
Jun 25, 2007 06:47 PM
