Sponsored by: Auxito
hub removal
Old Mar 14, 2005 | 02:04 PM
solomon's Avatar
solomon
hub removal
having problems removing hub. Seems to be frozen up. Any suggestions that might keep me from beating it to death with a big hammer?
Old Mar 14, 2005 | 03:25 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 15, 2005 | 12:31 AM
Racerguy's Avatar
Racerguy
Did you get it figured out yet?
4x2 or 4x4? What exactly won't come off?
Old Mar 15, 2005 | 07:49 AM
solomon's Avatar
solomon
97 F150 4x4
It's the hub and bearing unit, where the speed sensor is attached to. It should all just slide off. Think I need a gear puller. Had a cheap one and bent the ends out on it trying to pull it off. I got the steering knuckle off with it all still attached by unbolting the 4x4 axle from the case. I'd still like to know why the hub won't come off. Think I need a bigger and better gear puller and I could get it.
Old Mar 15, 2005 | 08:23 AM
Racerguy's Avatar
Racerguy
The hub where the wheel bolts onto doesn't come apart. All you can do with it is replace it.
There are 3 bolts that hold the assembly to the steering knuckle and the 36mm nut on the end of the axle. Once you remove the axle nut you push the axle in for room to access the 3 bolts on the back.
Old Mar 15, 2005 | 08:27 AM
solomon's Avatar
solomon
Correct, but I don't need to replace the hub (I hope). I've got the 3 bolts out from behind the steering knuckle, but the hub won't slide off the axle.
Old Mar 15, 2005 | 08:29 AM
solomon's Avatar
solomon
also have the axle nut off.
Old Mar 15, 2005 | 08:45 AM
Racerguy's Avatar
Racerguy
You need to push in on the axle to get it out of the splines. I use a big brass punch and good sized hammer. Once you have the axle out then the wheel bearing/hub assembly comes out of the knuckle.
What part are you replacing that you're taking it apart?
Old Mar 15, 2005 | 08:49 AM
solomon's Avatar
solomon
well, I'm replacing the lower ball joint, but by unbolting the 4x4 axle on the far end, I was able to get the steering knuckle off. The hub came with it. Now, I just want to service the hub while I'm at it, seeing as how there's something not exactly right with it.
