Internal slave cylinder question
Old May 31, 2001 | 01:34 AM
289freak's Avatar
289freak
I was wondering if anyone knows if I can use the internal slave cylinder on a BW t-5 5spd tranny? I'm planning to bolt this tranny into a 1966 Mustang and want to use a hydraulic clutch setup. One bellhousing I have (from a 90's model mustang) is set up for a cable clutch, and the the other bellhousing (from a F150) is set for a external slave cylinder. The problem is that the the F150 bellhousing to about 3/4" to short and would require an adapter plate to bolt the T5 to the bellhouse. I was wondering if I could use the internal slave cylinder and the Mustang bellhouse to save me some trouble.
Old Jun 2, 2001 | 08:56 PM
knuckles's Avatar
knuckles
Try an aftermarket hydraulic throwout bearing, such as those offered by McCleod. It's essentially the same (in principle) as the factory internal slave/ T.O. bearing assy, but it'll mount in your T-5 bellhousing.
Old Jun 2, 2001 | 10:38 PM
whomrig's Avatar
whomrig
