oiling problems
Old Mar 13, 2005 | 10:40 PM
bh2112's Avatar
bh2112
oiling problems
hi i know the fe's have oiling problems but is there any thing you can add or do without rebuilding i bought my 73 f100 360 about 6 months ago i was told it has a fresh motor and i just want to run it for a little long while but i just wanted to know if there is any thing i can do for it thank you
Old Mar 14, 2005 | 06:46 AM
jowilker's Avatar
jowilker
Keep the oil & filter changed regularly and it will last a long time.
John
Old Mar 14, 2005 | 10:38 AM
jstandle's Avatar
jstandle
Oil mods aren't critical, especially under regular driving conditions. MANY stock FE's have run over 200,000+ miles with regular maintanence. If you were rebuilding it, or had plans of running the pi$$ out of it then oil mods are high on the need to do list.
Most machine shops do the oil mods as standard rebuild procedure, but not all. If you were real concerned you could remove the oil filter adapter and see if the holes are larger, that would give you an idea.
Old Mar 14, 2005 | 05:29 PM
Annihilator's Avatar
Annihilator
You could put some oil restictors in the heads. Just a thought.
Old Mar 14, 2005 | 10:25 PM
bh2112's Avatar
bh2112
thanks it just seems to get noisey about 74 plus in the top end i don't have a tach i have 3.5 rearend gears
Old Mar 15, 2005 | 01:59 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
With those gears it should be ok to 100 mph unless the pump is shot, the bearings and top end are bleeding your oil due to excess bearing clearance.
Carl....=o&o>....
