First time poster and question. I did a search but I could not find my answer it could be there but!
I have a 1994 F350 XLT dually. I am changing the bed to a flatbed. I purchased a flatbed from wrecker and the wiring was chopped to pieces. This bed has side lights and 7 lights across the back 2 each side and 3 center lights as the bed exceeds 80". I am looking for a harness to wire all the lights into the OEM Plug. Anyone know where to start looking for such a harness?
I have wired several trucks and trailers. I have found that it is much cheaper to make a wiring harness yourself than it is to buy them. You could probably find the harness if the manufacturer of the body is still in business. My opinion, get some solderless connectors and some shrink wrap and make a harness. You can use your plug off of your dually bed so it plugs right in.
