2wd wheelbases
Old Jun 5, 2001 | 10:33 AM
slowsix's Avatar
slowsix
2wd wheelbases
The T18 to ZF is slowly coming along. The ZF is a longer transmission but the output shaft is closer to the front than the T18 which means I need a longer driveshaft (strange but true). Does anybody know if the wheelbase for a 1988 F150 2wd is the same as the wheelbase for a 1990 F250 2wd? If it is I can probably use a driveshft fromn the F250 in the F150 with a stepjoint as opposed to a custom driveshaft ($$$$). Thanks for the input.
1988 F150
T18 out ZF in but not running yet
4.9, 3.55
Old Jun 5, 2001 | 03:53 PM
slowsix's Avatar
slowsix
2wd wheelbases
Sorry. Forgot to specify that I am looking at both trucks being a regular cab, LWB, 8 foot bed.
Old Jun 10, 2001 | 11:04 PM
ddestruel's Avatar
ddestruel
2wd wheelbases
I don't think you can do that the 3/4 ton has a larger differential and longer pinion on the housing making the DL a different length. better wait for other responses though im not too familiar with DL's yet. The wheel bases are the same though, i wouldnt see any reason for different.
Best of luck
dusty
Old Jun 11, 2001 | 07:48 PM
canadianfordman's Avatar
canadianfordman
2wd wheelbases
oscar4pbr
Aug 1, 2010 08:17 PM
ludis
Jul 17, 2004 02:36 AM
ramboss429
Offroad & 4x4
34
Jul 2, 2004 11:29 PM
slowsix
Jun 10, 2001 09:31 AM
