Need Exploded suspension diagram 97 explorer
Old Mar 13, 2005 | 10:50 AM
jlouki01's Avatar
jlouki01
The peice that connects my front sway bar to the lower control has broken. I would like to replace it but I want to look at an exploded diagram first so I know what peices to buy.
Old Mar 13, 2005 | 11:21 AM
fefarms's Avatar
fefarms
If your truck was built before Oct 31, 1996, then Ford safety recall 00S47 applies. This recall was for (surprise) broken stabilizer bar links. In this case, drive the truck to the dealer and they will replace both sides for free. I had mine changed out under the recall on my 1996 Explorer years ago.
If your truck was built after Oct 31, 1996, then it should have come with the beefier links from the factory. You should be able to find a diagram on fordpartscheap.com
Alternatively, the dealerships are used to looking up the numbers as they had to replace a bunch of these under the recall.
Be careful not to overtorque the through bolts.
Old Mar 14, 2005 | 10:32 AM
460429_freak's Avatar
460429_freak
go to autozone and buy them $21 a side the factory ones are plastic autozones are metal tube with rubber end fix mine drive like a new explorer..
A/Ox4
19
Jan 12, 2018 09:35 AM
IsaacJR75
May 10, 2017 05:56 PM
pacrewchief
Dec 11, 2011 11:57 PM
hot51
Jul 6, 2009 05:34 AM
Cienega32
Mar 11, 2009 12:34 AM
