The rocker bosses are really the stands or what the bolts go into... I'm not sure what else to call them. It'll be to the intake side of the head when looking at it. I had to run out to my garage in my socks and look...
Matt, yeah it was pretty easy setup.Still tinkering with the air/fuel but it runs great.Having an issue now with restarting after running up to temp.After shutting it off and then trying to restart it cranks like it is out of time and you have to hold pedal to the floor. John
Yea.... mine does that too... I'm not sure what causes it, but it seems worse when I'm on an incline. I had to bump my timing ahead a little bit when it got real cold last January...
btw, I've seen several locations for the data stamp, but the most common is right in the flat spot between the rocker boss and the gasket area... sorry, no digital camera or I'd snap a pic...
