rear cab mount question
Old Mar 13, 2005 | 07:42 AM
seaves46's Avatar
seaves46
Hi Guys,
i've just bought myself a new cab for my 53 , it's had all of its rust cut out and panel beating done, all i have to do is fit and paint it.
BUT, my question is, i went to replace the rubbers in the rear cab mounts, and the small tube like rubbers that go in each end of the rear mount seem to be to loose. The old ones took a bit of effort to remove , but the new ones practically fell in.
Is this how they are supposed to be ?
if not, how can i fix it
Scott
Old Mar 13, 2005 | 08:06 AM
Earl's Avatar
Earl
Can't help on the question, but I'm just about there in my project and I'm interested in the answer.
Old Mar 13, 2005 | 11:09 AM
fking1's Avatar
fking1
Recently replaced these on my 55 which is the same mount. The rubbers were a snug slip fit in the steel tubes, also new. Did you get new steel tubes too? You could use silicone rubber from a tube and slather it on the outside of the rubber and assemble the mount. When the silicone cured it would form a good fit.
Fred
GreatNorthWoods
57
Nov 14, 2017 03:37 PM
ssg1957
Feb 12, 2015 10:07 AM
K9sicem
Feb 21, 2013 03:20 PM
javi2001
May 5, 2006 03:12 PM
51ford fan
Mar 10, 2005 08:57 AM
