'93 Explorer Temp. gauge problems???
Old Mar 12, 2005 | 08:12 PM
Irysh's Avatar
Irysh
Hi all. I have a '93 Explorer w/ 179K miles. The temp. gauge has recently developed a mind of it's own. A few days ago, I changed a heater hose and the upper radiator hose. After that, the temp. gauge started going up and down... the truck's not overheating, the needle just goes up and down between the cold line (in the normal range) and just above the "L" in NORMAL. It takes about 15 seconds for each cycle, with about 5 seconds in between. My first thought was air in the system, but I haven't been able to bleed any out. Next, I was convinced it was the thermostat. I've now changed it twice, with no change. During this, I found the cap to be leaking a tiny bit, so that's been replaced. Then I changed the coolant temp switch and the temp. sensor. The fan clutch is engaging, and the coolant appears to be circulating. I'm hoping someone here will have a suggestion. I 'm having to drive back and forth to Savannah to take care of my mother, and I have to leave again on Wednesday. Any help would be greatly appreciated!
Thanks,
Jen
Old Mar 12, 2005 | 11:15 PM
mrshorty's Avatar
mrshorty
I've seen a clogged heater core cause such behavior.
Old Mar 13, 2005 | 10:20 AM
Irysh's Avatar
Irysh
Thanks for the suggestion, mrshorty. I'm on my way out now to see of I can figure it out... I'll check that too.
Bigtruc
20
Dec 26, 2013 10:24 AM
a64armt
6.4L Power Stroke Diesel
16
May 10, 2009 09:18 AM
twinarrow99
1983 - 2012 Ranger & B-Series
Apr 11, 2006 09:32 PM
grousehunter
Oct 16, 2004 02:05 AM
