My check engine light came on and pulled a P0401 code "EGR FLOW INSUFFICIENT". I've replaced the EGR valve, the Vacuum Solenoid, and on a suggestion of a friend the PCV valve all to no avail.
<!--[if !supportEmptyParas]-->
And now I'm also getting a P0125 Closed loop fuel CTRL Insufficient Coolant temp. Can anyone give me some direction on what to try next?
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
