fuel tanks
Old Jun 12, 2001 | 05:41 PM
billyb's Avatar
billyb
fuel tanks
hey out there! has anyone changed from dual tanks to single tank?? if so, what was involved?. i'm growing tired of never getting accurate reading on gas gauge, and of problems with front/rear tanks filling one another.
thanks for any replies!
Old Jun 13, 2001 | 12:48 AM
crazy_goodolboy's Avatar
crazy_goodolboy
fuel tanks
Don't expect to get accurate readings just because you only have one tank! I've never seen a fully accurate fuel gauge in my life.
Old Jun 13, 2001 | 11:47 AM
loudfords's Avatar
loudfords
fuel tanks
The only thing you need is to get a separator valve thingy from a single tank van or truck. This goes in place of your current one that has 4 lines on the back and 2 on the front and is on the driver side frame rail. The single tank version has 2 lines in front and 2 in back. Believe me you need it for your fuel pump to run properly. I currently have one in my dual tank truck after I pulled the rear tank out because it was leaking. You can just leave your dash selector switch in on the tank you use and forget about any rewiring.
Hope this helps.
1979 F150 Custom: nothing under the hood at all (again)
1987 F150 XLT Lariat: 88 351W EFI
75 351W: soon to have 91 heads, ?? cam, double roller timing chain, Edelbrock Performer intake & Holley carb and be put back in 79 F150
84 351W: waiting for ???
Chevy 454: waiting for a truck (Mazda?Nissan?)
Old Jun 13, 2001 | 09:32 PM
billyb's Avatar
billyb
fuel tanks
thanks for info guy's. i just want a fuel gauge that doesn't always read completely full or completely empty!!.
i will check into seperator next chance i get.
Old Jun 17, 2001 | 02:30 PM
cbwarrior's Avatar
cbwarrior
fuel tanks
I had the same problem-> reads full until about 1/3 tank left, then reads empty. All that you have to do is replace the internal fuel pump module. I only have the rear (single) tank set-up. I got a new tank from Advance Auto Parts for about $100. Gauge reads perfect now.
88 F-150 4X4 XLT Lariat w/5.0 EFI 5 spd (DAILY DRIVER)
86 Ranger 2WD w/2.3L EFI 5 spd to be 351W 4bbl C4 (NEW TOY- DETAILS WHEN FINISHED)
85 Old Cutlass Supreme 350/TH350 Holley 4160,Edelbrock Performer intake, el-cheapo headers, High Energy Cam 270H series cam, 15.588 best 1/4 mile with original 10 bolt 2.41 gears (OLD TOY)
Old Jun 17, 2001 | 03:56 PM
Steve91's Avatar
Steve91
fuel tanks
merbno
Oct 14, 2014 05:36 PM
stopp429
Feb 15, 2013 06:42 PM
iontkendall
Dec 21, 2010 04:53 PM
breedo99
13
Mar 25, 2010 09:07 PM
k3ke
Feb 2, 2002 06:57 PM
