Ford 9'
Old Jun 10, 2001 | 09:06 PM
Franklin2's Avatar
Franklin2
Ford 9'
Old Jun 21, 2001 | 03:06 PM
nickc84's Avatar
nickc84
Ford 9'
How do I know if I have a 9' in my 85 F-150? From the door jam code I have 3.55LS, but I would like to know if its a 8.8' or 9'. What is the difference between the two, and why is the 9 used so much in hot rods and other restored cars? And why is it so special?
Thanks,
Nick
"Speed equals money how fast do you want to go?"
Old Jun 21, 2001 | 06:27 PM
brown 4x4's Avatar
brown 4x4
Ford 9'
The 9" rear has a non-removable cover and the 8.8" has a removable cover. The 9" is supposed to be alot tougher than the 8.8, although I've never had a problem with either.
Old Jun 21, 2001 | 07:55 PM
Franklin2's Avatar
Franklin2
Ford 9'
Previous poster is correct about the covers. The 8.8 has a rear sheetmetal cover(which your 85 probably has). Hot rod guys like 9 inchers because the whole pumpkin comes out of the front of the rear, making gear ratio swapping easy with no complicated gear set-up. The 8.8 is pretty strong but I do not like the way the wheel bearings run directly on the axle.
Old Jun 22, 2001 | 12:36 PM
crazy_goodolboy's Avatar
crazy_goodolboy
Ford 9'
Ford 8.8"
http://www.coloradok5.com/techpics/ford88in.jpg
Ford 9"
http://www.coloradok5.com/techpics/ford9in.jpg
Old Jun 22, 2001 | 01:05 PM
nickc84's Avatar
nickc84
Ford 9'
Thanks guys, turns out I have a 8.8'
thanks for the diagram that really helped.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
