1997 Ford F-350 Diesel Smokes heavy on start up!
I have a 1997 Ford F-350 powerstroke diesel. It has 83,000 miles. When i start it it smokes a blueish smoke that stinks and burns your eyes. It does it in warm and cold weather. After a minute of driving it does not smoke at all. The truck does not burn oil. It has been to 3 different diesel mechanics and there are no codes.
New Parts:
-Glow plugs
-glow plug relay
-injector o-rings
-cam sensor
-new fuel filter
-exhaust back pressure valve
Have any suggestions ???????
Thank you
New Parts:
-Glow plugs
-glow plug relay
-injector o-rings
-cam sensor
-new fuel filter
Thank you
Wow it's hard to say with all the new parts. How thick is the smoke? my truck smoke a little at start up but it's mostly white, which I concluded through this excellent forum is normal for these trucks at cold temps and first start ups. I also have an exhaust system which excludes the cat and the fumes are pretty harsh to many but I love em'!
1997 Ford F-350 diesel exhaust pressure valve
My 1997 Ford F-350 Powerstroke diesel with 83,000 miles. On cold days it will drop in rpm's when in park or neutral it will go from 1,500 rpm - 1,100 rpm and stay there for around 5 seconds and if you give it gas the idle will jump right back up with no problem. Then it will repeat this process again. When driving you will feel the rpm's drop by about 200rpm. Once you drive the truck and shut it off the problem goes away untill the truck sits and gets cold. Cant find any computer codes.
New parts
Exhaust back pressure valve
Fuel filter
Glow Plugs
Glow plug relay
Cam sensor
Injector o-rings
Any suggestions? Thank you!
New parts
Fuel filter
Glow Plugs
Glow plug relay
Cam sensor
Injector o-rings
New parts
Fuel filter
Glow Plugs
Glow plug relay
Cam sensor
Injector o-rings
New parts
Fuel filter
Glow Plugs
Glow plug relay
Cam sensor
Injector o-rings
If this turns out to be your problem, I can dig up part numbers for you.
Good luck.
New Parts:
-Glow plugs
-glow plug relay
-injector o-rings
-cam sensor
-new fuel filter
Thank you
New Parts:
-Glow plugs
-glow plug relay
-injector o-rings
-cam sensor
-new fuel filter
Thank you
