Engine running rough
Old Mar 11, 2005 | 06:07 PM
1984 f-250's Avatar
1984 f-250
on my 92 explorer when i press the gas it stumbles and then once its moving its fine. At idle the RPM jump between 800-1000. I have a new IAC, fuel filter, spark plugs and wires also i clean the MAF but it still runs poorly. Any ideas?
Old Mar 11, 2005 | 08:05 PM
JerrySimm's Avatar
JerrySimm
Have you checked for a vacuum leak? Check the hoses and the intake hose tree back near the brake boster. Have you tried pulling any codes from the computer?
Old Mar 11, 2005 | 08:53 PM
1984 f-250's Avatar
1984 f-250
I looked at the vacuum tree and it seemed ok. Does anyone know of the website that shows how to pull the OBD 1 codes.
Old Mar 11, 2005 | 08:58 PM
JerrySimm's Avatar
JerrySimm
You can either go get a code reader from the parts store, or you can try the procedures shown here http://dalidesign.com/hbook/eectest.html . Also, some parts stores will pull the codes for you in hopes that you'll buy parts to fix the problem.
Old Mar 12, 2005 | 10:43 PM
1984 f-250's Avatar
1984 f-250
Can anything else cause the idle to drop to 500-700 rpms other than the IAC
Old Mar 12, 2005 | 11:11 PM
mrshorty's Avatar
mrshorty
Other interruption in air intake, dip in the fuel pressure, misfire, vacuum leak, other EEC-IV problem.
Have you pulled codes, yet? Can you test fuel pressure?
Old Mar 14, 2005 | 02:07 PM
1984 f-250's Avatar
1984 f-250
Well i had to take my explorer into the dealer because now its not running.
