Aerostar Ford Aerostar
Tranny swap
Old Mar 10, 2005 | 10:06 PM
savagefan's Avatar
savagefan
Tranny swap
Hello, does anyone know if an a4dl from a 91 'star 4.0 will fit a 90 with a 3.0? Am hoping to do the swap this weekend all help greatly appreciated.
Old Mar 10, 2005 | 11:58 PM
copper_90680's Avatar
copper_90680
If I'm not mistaken, it should fit, with the possible exception of the bellhousing. If the bellhousing is different, you can take the 3.0L bellhousing and put it on the 4.0L tranny.
Of course, you understand that you are doing this at your own risk, since I'm no tranny expert. My opinion is just an opinion, not facts
Old Mar 11, 2005 | 10:02 AM
93nighthawk's Avatar
93nighthawk
Not absolutely sure, but the Torque converter and shaft might be different dimmensions. I know the bell housing IS different, so you would need to keep your old one.
Old Mar 11, 2005 | 10:11 AM
Monty06's Avatar
Monty06
hello second post in this forum i mainly stay in b2 or ranger forums
yes you can do the swap here is the thing you need to take off your bellhousing and place it on your donor tranny your TC and the shaft might be different so keep those parts. also check the valve setup when you remove the pan you can see your seloniod setup and make sure it's the same. if not you might have to swap that too.
