Air Suspension help!
Old Mar 10, 2005 | 09:25 PM
mltnwil's Avatar
mltnwil
My 98 expedition is having extreme air susepension problems. About a month ago the suspension was stuck up very high for approx a weekl I manually adjusted the sensor in the rear. Now the suspension is too low. I adjusted the sensor about three days ago but the compressor doesn't auto come on. I have troubleshot the relay and that might be part of the problem as I can short the relay and get the compressor to run, and it looks as though the front of the car is raising up but not the rears at all. Anyone have any thoughts. Could the air lines possible have moisture that is blocking air passage to the rears It has been very cold for the past two weeks?
Old Mar 11, 2005 | 12:32 AM
david.brady's Avatar
david.brady
Welcome to FTE, the site is awesome. Your title caught my eye, I have an air suspension, I think in my EB. I think you may be on in thinking the air and cold theory. I am sure someone will come on an give you a better idea than my insight.
Be sure to read the guidelines and use the search function. The administrators won't let you go wrong.
BAD RONALD
21
Oct 25, 2017 08:45 PM
jaytuck
1997 - 2003 F150
20
Jun 10, 2016 05:21 PM
rschleicher
Jul 7, 2009 07:04 PM
rschleicher
Sep 12, 2008 09:18 PM
beegeezee103
Nov 2, 2006 12:28 PM
