Hello All!
I just bought myself a 77 F350 CC 4x4 and thought I'd chime in here and say hi!
It's in pretty rough shape (just retired as a plow truck in BC, Canada), but I plan to fix her up and make a capable offroader. I have a few things to ask you guys about too.
It has a 460 in it right now.. I'm thinking I'll either:
- Convert it to propane.. Has anyone tried upping the compression to 13:1 on propane.. does this help mileage?
- Put a cummins diesel in it from a 94ish dodge. I know people have done this.. I'm a diesel nut so ..
If I did this I'd consider an overdrive unit as it has the 4 spd in it.I'd also like to build a lower exo cage (just around the front wheel well onto a rock slider under the rocker panel). Anyone know of any pictures of exo's on these trucks? I don't want it to look too ugly!
Anything else I should be concerned about? Want to get 36 - 40ish tires on there, flexy suspension mods etc. Steering problems in these old beasts?
I'll try to get some pictures soon.
Thanks!
Ian
EDIT:
OK, so I guess I lied.. it's a 76 F250 CC (I think.. it says 'F252' on the inner door).
Anyone know what this would have for a tranny, transfer case, and axels? Thanks!
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
