FX4 owners and those w/aftermarket flares
I just got a set of flares like the ones on the FX4 for my XLT. I am concerned about sealing them to prevent corrosion.For those of you with the FX4, is there a seal around the fender flare or something like that. Pics would be great. For those with aftermarket flares, did yours come with any kind of strip to seal out water, salt, ect. Or should I worry.
Thanks
DRG3
Thanks
DRG3
Originally Posted by DRG3
[font=Times New Roman][size=3]I just got a set of flares like the ones on the FX4 for my XLT. I am concerned about sealing them to prevent corrosion.For those of you with the FX4, is there a seal around the fender flare or something like that.
Larry in SF, CA
DRG3...I second that finding...no sealant of any type, and a very tight fit.
Personally, I wouldn't put any sealant (foam, etc.) in there because it might trap moisture. But like likalarry says, I would put some schmutz or corrosion preventive compound in the holes you drill in the fender (not that the boyz in KC did when they drilled mine!).
And by the way, welcome to FTE...a great site for serious Ford Truck owners!
