2006 Super Duty
Old Mar 10, 2005 | 10:30 AM
Jossdoit's Avatar
Jossdoit
2006 Super Duty
Does anyone know when Ford will start production of the 2006 Super Duty's? Also what is the earliest you can place an order for a 2006?
Does anyone know what changes, if any, there are going to be to the 2006 Super Duty? I am guessing the price will be going up. Where can you find information on this ?
Thanks for the help!
Old Mar 10, 2005 | 10:44 AM
TDN's Avatar
TDN
According to BlueOvalNews, there are different dates for SD according to the two different plants (Kansas City Truck vs. Cuautitlan Mexico).
http://www.blueovalnews.com/2005/pro....04march05.htm
And interestingly enough, this is showing a 2006 Job #1 date of 9/6/05 for the Excursion. I thought the X was discontinued as of the 2005 MY?
Old Mar 10, 2005 | 12:00 PM
Jossdoit's Avatar
Jossdoit
What is the Job #1 thing mean? Do they build certain trucks at the different plants? If so, do you know which are built at either plant? Thanks for the info!
Old Mar 10, 2005 | 12:08 PM
TDN's Avatar
TDN
Job #1 means the beginning of production for the new model year. I believe there can be a Job #2, mid-year production change, including design tweaks, production process changes, etc. I don't know which models of SD trucks are built at each of the two plants.
Old Mar 10, 2005 | 01:29 PM
1956MarkII's Avatar
1956MarkII
Once again, Blue Oval News gets it wrong. Super-Dutys for U.S. consumption are built in Lousiville, period. Production was to begin May 2nd, but it's been pushed back to May 14th. The 2005 Excursion will be built at least through August; that tells you there will be very few changes to the '06 S/D. There will be no 2006 Excursion. Job 1 is the first run of vehicles; Job 2 would be any changes to the first run, Job 3 is any changes to the second run, etc...
Old Mar 10, 2005 | 02:55 PM
TDN's Avatar
TDN
Thanks for the clarification Jeff. Wow, you would think they would have better fact checking over there.
Old Mar 10, 2005 | 03:48 PM
SirHailstone's Avatar
SirHailstone
BON is a rumor site. I sometimes wonder how many times they get fed "red herrings" just to see what all they will post.
Old Mar 11, 2005 | 06:40 PM
Jossdoit's Avatar
Jossdoit
Which job # is it best to order? Is a Job #2 truck better than a job #1? Jeff, do you know what changes there are in the '06 SD? I plan on going to other dealers and drive their trucks and then order from Jeff. I just want to drive a Lariat V10 and they are kinda rare as most Lariat's are PSD's.
Old Mar 12, 2005 | 11:05 AM
1956MarkII's Avatar
1956MarkII
There's no way to order one job or another. If Ford decides to make changes, then they switch to the next job, and you and I have no say in it. Some changes are good (improvements to the product), some are bad (what was once standard is now gone, like rear wheel-well liners).
Old Mar 12, 2005 | 07:45 PM
richfaa's Avatar
richfaa
Just look at your VIN the 11th position tells you where it is built....E....is KY
Old Mar 12, 2005 | 10:29 PM
BigFord74's Avatar
BigFord74
So when can you expect to see the color and options of the '06. It seems i'm to late to order my '05.
Old Mar 13, 2005 | 03:00 PM
93-331-29PSI's Avatar
93-331-29PSI
They are still taking orders for the 05 until April 1 2005 according to the link listed above by TDN
Old Mar 13, 2005 | 03:17 PM
sglaine's Avatar
sglaine
Posting Legend
I hope the 06 will be better then the 05s are.
