Distributor Question
Old Mar 10, 2005 | 12:03 AM
JARedman's Avatar
JARedman
I was cleaning a spare distributor I have about. It looks and feels pretty good. How do you tell if a distributor is worn out? It came out of a 74 360, and I plan to use it in a stock 66 352 rebuild. Thanks , JR.
Old Mar 10, 2005 | 01:29 AM
FordPickup460's Avatar
FordPickup460
Wiggle the shaft in the middle of it and see if it moves. If it moves alot that means the bearings are shot.
Old Mar 10, 2005 | 12:25 PM
ford390gashog's Avatar
ford390gashog
yes or a rebuilt is only 30.00 you should put in a points eliminator kit to replace the points
Old Mar 11, 2005 | 05:43 PM
JARedman's Avatar
JARedman
Thanks for the replies guys! It has very little play, side to side, on the shaft, so in it goes. I have a pertronix set up triggering a Jacobs coil and a mileage master control that will be transferred from the tired engine. Thanks again.JR
