Transfer Case Shift Motor??
Old Mar 9, 2005 | 10:49 PM
rollinXplorer's Avatar
rollinXplorer
97 SOHC Control trac 4wd
My transfer case sometimes gets stuck in 4wd low, by hitting it with a hammer causes it to usually shift out and works fine. Will replacing the shift motor:
“A1 Cardone Part # 48204
4WD {[Transfer Case Motors]Reman.)”
$56.79 at www.rockauto.com
Fix my problems? Or is it something more serious?
Thanks,
Joe
Old Mar 12, 2005 | 07:42 PM
vicv's Avatar
vicv
I took my shift motor out and cleaned the armature, put it back in and it's been fine since. But if you can get a reman for under 60 bucks I'd go that route. Maybe clean the old one and save it just in case.....
Old Mar 12, 2005 | 08:14 PM
B. Abel's Avatar
B. Abel
I also took my shift motor out and cleaned the armature, put it back in and it's been fine since.It took 2hrs and the inside was perfect, like new, except for some carbon tracking, I cleaned that up and now it works perfect for the first time since I bought the truck.
Old Mar 14, 2005 | 04:15 AM
sjwoody's Avatar
sjwoody
check this out
http://www.marx7.org/~dsmith/t-fer_case_motor_fix.htm
good luck.
staplegun
Bronco II
Feb 17, 2025 08:04 AM
tomoto
21
Mar 4, 2007 11:05 AM
sandjunkie
Mar 24, 2006 03:33 PM
Crash!
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Jul 21, 2005 09:37 PM
mcpcola
Aug 5, 2004 03:19 PM
