Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Stalling while cold
Old Mar 9, 2005 | 06:32 PM
Trucky18's Avatar
Trucky18
Stalling while cold
I have an 02 and it stalls out/does not want to start when its cold out. It will turn over just fine, but it will not start. After while it will start, but then want to stall. Even after it gets running it will tend to stall otu when I put it in gear. It seems like a fuel problem to me, but I wasnt sure, its got 40,000 miles on it, would a fuel filter be a likley canidate? Is the fuel filter on the frame rail like most cars? I just havent had to time to look at it, yet. does anybody have any ideas/tips? Thanks
Old Mar 10, 2005 | 09:00 AM
ove1's Avatar
ove1
The IAC (idle air control) may be sticking. It's the silver cylindrical object mounted above the throttle body with two screws. Does it start better if you crack the throttle?
The fuel filter is mounted underneath, left-rear, back by the fuel tank.
Old Mar 10, 2005 | 11:38 AM
Trucky18's Avatar
Trucky18
Ill check the IAC thing, and get back with ya.
Old Mar 10, 2005 | 02:05 PM
Trucky18's Avatar
Trucky18
give it throttle while starting it did not make any differance. Could this be a simptom of bad gas?
Old Mar 10, 2005 | 03:01 PM
ove1's Avatar
ove1
Could be bad gas. Does your locale add alcohol to the winter gas mixture? If not, try adding a bottle of Heet Isophropyl alcohol to the tank to absorb any moisture in the tank. Also try filling up at a different station. If that doesn't help, I would try running a bottle of Techron injector cleaner through with the fresh tank of gas.
stxchck13
Apr 13, 2013 07:31 AM
smashclash
Feb 22, 2011 03:13 PM
BroncoBoss351
1978 - 1996 Big Bronco
Mar 29, 2006 11:57 PM
macaroni22
Sep 15, 2004 02:11 PM
