Sponsored by: Real Truck
Swapping Motors
Old Mar 9, 2005 | 05:44 PM
PITBULLFXST's Avatar
PITBULLFXST
Swapping Motors
Does anyone know if you can swap out a 5.4 gasser for a 2003 6.0psd in a 2001 f250? If so how difficult would it be? I am looking at a buying this 250 with a blown motor and I have a extra 6.0psd.
Thanks for all your help.
Pittbull
Old Mar 9, 2005 | 08:41 PM
Dave Sponaugle's Avatar
Dave Sponaugle
You are going to need a lot of parts and wiring. Gas to diesel is hard, gas to Power Stroke is real hard. To much computer stuff to have to wire in the gas truck. Transmission will not work, fuel system will not work, cooling system will not work, electrical system will not work, exhaust system will not work. Other than that it should be a piece of cake.
Old Mar 9, 2005 | 09:17 PM
99f350sd's Avatar
99f350sd
Of course it can be done. If you have endless money and time..I've done projects like that its amazing what comes up! I wouldn't even consider it and I'm pretty brave.
Save and buy what you want..My 2 cents
Dick
Old Mar 9, 2005 | 10:22 PM
92f150I6's Avatar
92f150I6
It may be easier and cheaper to swap in a cummins as their are kits for that. You could purchase all of the necessary wiring form ford, and all of the other parts, or find a possible junkyard donor, but, you would probably be better off buying a diesel truck.
