New user from Canada
Old Mar 9, 2005 | 05:38 PM
mazdaford's Avatar
mazdaford
Thumbs up New user from Canada
Hello all. My name is Adrian, I own a 1998 Mazda B4000 4x4 (same as Ranger). I am from New Brunswick in Canada. I have had trouble with the Vacuum hubs but have done the fix where you remove the metal clip to make them engaged all the time. Everything is fine now, except for the occasional flashing 4hi and 4lo lights when switching to 4wd. which is I believe caused by the vehicle speed sensor, I will replace that when the weather warms up. I found that if you remove Fuses 25 and 26 for 1 minute it will reset the flashing lights on the dash, and enable 4wd to work again. This is great forum with lots of good info.
Old Mar 9, 2005 | 06:26 PM
Fordlover55's Avatar
Fordlover55
Still kicking!!
Welcome to the site.
Please make sure you read the forum guidelines and the READ FIRST notes in each forum you visit. They'll get you off to a good start. Also, check out the State and Regional Chapters. There's a great bunch of folks waiting to meet you.
Old Mar 9, 2005 | 10:32 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Mar 10, 2005 | 07:14 AM
PSKSAM2's Avatar
PSKSAM2
Adrian,
Welcome to FTE. That's a great truck, I have about the same one. Good luck with the 4x4 issues, sounds like you have them tracked down quite well.
-Jim
Old Mar 10, 2005 | 02:50 PM
Rockledge's Avatar
Rockledge
Welcome and thanks for the feedback on the PVH 4x4 system.
