rear end ratio
Old Mar 8, 2005 | 04:42 PM
Ilovemyranger's Avatar
Ilovemyranger
rear end ratio
I bought my truck used so I don't have the sticker...is there anyway to tell what rear end gear ratio is in my truck?BTW,its a 2000 4.0L extended cab w/4x4 off road package...thanks.
Old Mar 8, 2005 | 07:45 PM
Ken00's Avatar
Ken00
There's a tag on the rear, I bet its a 3.73 or 4.10.
Old Mar 13, 2005 | 11:48 AM
svdweb1's Avatar
svdweb1
If the tag is not present, you can get a rough estimate by putting a chalk line on the tire and on the drive shaft. With the vehicle jacked up spin the wheel and see how many times the drive shaft spins with a full tire rotation. If the shaft spins about 3 3/4 times you probably got the 3.73. If it spins a little over 4 times you probably got the 4.10. To get it exact you can remove the differential cover and count the teeth on the ring gear and pinion gear then divide the two to get the ratio.
Old Mar 13, 2005 | 10:06 PM
98xlt4x4's Avatar
98xlt4x4
Two easy ways to tell...
1) On the back of the rear differential there's a metal tag sticking out, with various numbers on it, like 8.8 for the 8.8" rear end, and probably a 3 73 or 4 10 for gear ratio. If there's a L between the numbers ( 3 L 73 ) then it is a limited slip. Or . . .
2) The sticker in your door jamb will have info on it. One section will have the Axle code, 97 or R6 or something. Go to http://www.therangerstation.com/tech_library/Axles.html for all the info you might need.
By the way, anyone here running 4.56 gears in their ranger?
