Sponsored by: Real Truck
where do I get electric power?
Old Mar 8, 2005 | 02:41 PM
windyhill's Avatar
windyhill
Quick! I'm in the middle of wiring up my air springs, and need to know where to get a hot, and an ignition wire under dash. I have four wires hanging, (Not the pass through wires) that are on right side of steering colum. Bright Blue, red, black, white, and small violet/pink stripe (Ignition Hot). where do these go? I've already pluged my brake controler in to the harness so I don't think there for that? It dosen't look like it's very easy to get to the back of the fuse box either. Can I get a wire from there? Help! thanks. 01 XL F350 4x4 Ext. cab.
Old Mar 8, 2005 | 02:44 PM
crecity678's Avatar
crecity678
got a voltage meter?
Old Mar 8, 2005 | 02:49 PM
windyhill's Avatar
windyhill
yes, but I didn't try it, just used the old test light..
Old Mar 8, 2005 | 03:02 PM
Steina's Avatar
Steina
CO River Rat
Sorry - duplicate!
Steve
Old Mar 8, 2005 | 03:04 PM
Steina's Avatar
Steina
CO River Rat
Those wire colors sure sound like the brake controller harness. See if red has power when the brake pedal is pushed.
Steve
Old Mar 8, 2005 | 03:11 PM
windyhill's Avatar
windyhill
Thanks, maby they are just another place to splice in a brake controler, I'm going out to check right now. How about where to get power from? On my old truck I pulled from off the back of the fuse box, but when I opened the back of this box, there was a circuit board! not helpful for hooking wires into.
Old Mar 8, 2005 | 03:17 PM
Steina's Avatar
Steina
CO River Rat
If that's what it is, then pink is hot (not switched), white is ground, and black is running lamps.
Steve
Old Mar 8, 2005 | 04:36 PM
windyhill's Avatar
windyhill
Nope, violet/Pink is switched, and others are not effected by brakes etc. I cant seem to find the other end of the "through wires" under the dash either. where are they again? help!
