GEAR info needed
Old Mar 15, 2005 | 11:26 AM
64f10's Avatar
64f10
Speedo was still reading fast on the intial load ... so I bumped "up" the revs/mile 3 notches ... sorry, a correction on the 4 from above ... 4 was how many times I loaded tune last night.
As for the shift points, they were way too high in my book at well over 5k ... brought mine way back down to 4700 something for 1-2 and 4800 something for 2-3. 3-4 is at 5k and that still gets a touch of belt squeal so I'll probably bring it down to 4800ish on my next load. And on the firmness settings I have all points set far left to the stock position. Still kicks a nice solid shift with some throttle while staying nice and smooth the rest of the time.
I'm guessing mine can't suck or blow enough air to really pull any power past or near 4900 RPMs as the rest is all stock.
Old Mar 15, 2005 | 12:34 PM
grey77's Avatar
grey77
BlkButy, is it possible to make your truck look any better? I love your truck!
everyone above is pretty much on the money. according to my calculations, if you did nothing, adding 37" would effectively turn your 3.73 into 3.13's - kinda weak hugh.
4.45's would return you to stock, but since there's no such thing, go with 4.56's at a minimum.
Old Mar 15, 2005 | 08:21 PM
Toreador's Avatar
Toreador
I have 30" tires with 3.55 gear. I'll be going to 32" tires later with 4.11 gear.
Old Mar 15, 2005 | 09:10 PM
ttymen's Avatar
ttymen
Do you think that will be enough? It seems like 4:56 precision gears with the predator are the way to go. Like I said earlier I'm pretty new to this, and from the feedback I'm getting back that seems like the right combo, then again I don't have any plans on towing, I just want better acceleration in the city, and from what I'm hearing the MPG get a little better in the city, I don't have a heavy foot, buy every once in while I want to give those Dodge & Chevy trucks a little run for there money. Thanks for everybodys help. I want to have my truck in the shop soon, and I just want to make sure I make the right decision.
Old Mar 15, 2005 | 09:34 PM
Toreador's Avatar
Toreador
For my needs it will be enough. I'm even OK with my current setup, but would bet the torque experts here would hate it. The 4.11s will be better than the 3.73 Ford likes with 32" tires and still give good gas mileage. It's sort of a compromise choice.
Old Mar 15, 2005 | 09:36 PM
WhëëlMå1's Avatar
WhëëlMå1
4.11s and 31-2" is where its at! I wish Ford offered the 4.10 outside of the HD package.
Old Mar 16, 2005 | 07:16 AM
Robert045.4's Avatar
Robert045.4
He's right. On a 2WD with only 32" upgraded tires, the 4.10 is perfect ratio and compromise. Ideally a 4.30 would be best suited, but the 4.10 will still be better than the crap Ford gives you.
Old Mar 16, 2005 | 04:00 PM
Ford-man22's Avatar
Ford-man22
Hey guys, I just got the Reider Gears 2005 catalog today. They DO NOT make a Percision Gear 4.88 for an 8.8 Reverse cut front end. Only 4.56. So I guess the 4.88 is out the window.
Old Mar 16, 2005 | 04:10 PM
grey77's Avatar
grey77
Just a question - because these trucks are "computer" controlled, do the (truck) computers need to be "informed" of the new gear ratio, or what? For sure the speed odometer can be thrown off, but are any other truck "systems" effected, by the new gear ratio I mean???
Old Mar 16, 2005 | 05:17 PM
industrialjunk's Avatar
industrialjunk
Nope your in luck Currie makes a 4.86 reverse cut 9" PN CHP-486R $249.95, bolts in with no problems. Yes a 9" is the same bolt pattern as the 8.8 in the front. 4.86 is close enough to 4.88.
Old Mar 16, 2005 | 07:38 PM
64f10's Avatar
64f10
Right after my 4.56 gears things didn't feel right (shift, power, etc...). Much as I expected for being out about 26-28%, then 2 days later had Ford service dept update the PCM getting me to about 12% ... Oh, so much better but still not quite right.
I still drove it every day. When the tuner arrived I dialed it in and things are back to, or feel, normal. Actually better than normal.
So, my thought is … yes, the computer needed to match what was going on rotationally. Just my unscientific opinion based on how things felt.
Old Mar 16, 2005 | 08:22 PM
ttymen's Avatar
ttymen
What brand and model tuner did you go with?
Old Mar 16, 2005 | 10:01 PM
  #28
64f10's Avatar
64f10
Much thought, long hours of reading and talking to others brought me to a decision on the Diablo Sport Predator. Several of my preemptive what if's coming into play, make me very glad I went this route. I almost went with a complete package deal from ******'s, but I'm quite glad I didn't now!
04 SCrew 4x4, Volant w/ram, Corsa Touring, 4.56 R&P
Old Mar 17, 2005 | 09:46 PM
  #29
lifted's Avatar
lifted
Hay guys i would like to know if someone knows wear to buy a 4.88 gears because I'm putting 37" on the truck.Precision gears only goes to a 4.56.
please write back
Leatherneck007
33
Aug 21, 2014 09:06 PM
porter4life69
2004 - 2008 F150
Mar 28, 2011 01:27 PM
Johnlwlr
Sep 22, 2010 10:17 AM
RangerPilot
1983 - 2012 Ranger & B-Series
69
Jan 14, 2009 05:23 AM
robjs111
Sep 2, 2007 09:15 PM
