Sponsored by: Auxito
97 Differentials
Old Mar 7, 2005 | 10:44 PM
zman764's Avatar
zman764
97 Differentials
Hey all,
I have a 97 150 4.6 4x4 w/ 175k
Sadly i have open differentials, 3.55.
I plan on doin some liftin over the summer, and some larger tires, not huge, 4 inch or so lift, with like 33's.
But First I want lower gears in the front and rear and lockers. What is the best, cheapest, most reliable route.
Note* I plan on having a local shop do the gears for me, as I have no experience/ability as far as the diffs. go.
Any and all help/recommendations are appreciated.
O yea i was thinkin 4.10 at least, would this kill my highway rpms, i dont want to turn 2,750 rpms in od at 70 yuh know?
Old Mar 8, 2005 | 04:03 AM
SHUSTANG's Avatar
SHUSTANG
4.10's should be fine. thats what i had in my 98 and it tached about 2500 at 75 and my tires werent true 33's. youd like them.
Old Mar 8, 2005 | 03:30 PM
fordman311's Avatar
fordman311
What would this do to acceleration/torque?
Old Mar 8, 2005 | 04:27 PM
SHUSTANG's Avatar
SHUSTANG
acceleration is definitely better. torque is the same but you feel more of it.
Old Mar 8, 2005 | 08:51 PM
zman764's Avatar
zman764
Well I put more thought into it, and now im thinkin either 4.10 or 3.73 i dont want to put alot more stress on my tranny/engine, and i dont want to turn 3k rpms at 75 drivin down the interstate. But I defanintley want more lowend power, thinkin 3 or 4 " lift, w/ 33" mudders.
My truck has open differentials on it. So I naturaly I want a locker. I pulled a friend out once, some 4 inch thick loose wet clay, and i tried to back him out with a chain on my front hooks, and i only had 1 front wheel and 1 rear wheel spinin, i couldnt move him, so i spun around hooked the chain to my hitch and pulled him out in forward, and all four wheels were spinin.
When im in 4 hi or 4 lo, is my front end locked out? Cuz all 4 wheels always spin, in mudd
I want the most reliable locker, that wont hurt my daily highway drivin, I assume detroit locker? What do yall recommmend?
Old Mar 8, 2005 | 10:00 PM
SHUSTANG's Avatar
SHUSTANG
the bigger the tire the lower the rpm. like i said my tires werent true 33's(more like 31.5) and i was turning 2500 at 75. at 75 with true 33's itll be lower than that. lower gears are less stressful on transmission. the only thing they might be a little harder on is the axles. im guessing you already have 3.55's and i figured it was only gonna be about 100-200 rpm difference with stock tires. checked on an rpm calculator. going to 4.10 from 3.55 is like a 450 rpm climb. i just put 4.10's in my 01 with 33's and almost wish i would have went with 4.56's. everybody says that 4.10's are way too much aand its not a low gear when you combine it with a bigger tire.
Old Mar 8, 2005 | 10:01 PM
zman764's Avatar
zman764
yea, did u put the 4.10 in front and rear diff?
Old Mar 8, 2005 | 10:03 PM
SHUSTANG's Avatar
SHUSTANG
yep the 98 and the 01.
