Sponsored by: Auxito
Transmission Fluid
Old Mar 8, 2005 | 10:02 AM
sbeII's Avatar
sbeII
Transmission Fluid
How often do yall change your transmission fluid?? I just recently changed the front and rear differential lube and was curious how often the transmission fluid needs to be changed. My f-150 has 82,000 and i bought it used about 15,000 miles ago and have not changed it since then.. besides that it could be 82,000 miles old for all i know. Is there a way of looking or smelling the fluid to see if it is old?
Thanks,
John
99 f-150 ext. cab
rear steel buper..grilleguard w/4 KC lights
tool box..bed linner
dual exaust..K&N air intake...<COMMENT> (9:29:04 PM)</COMMENT>
Old Mar 8, 2005 | 10:07 AM
PaulC's Avatar
PaulC
If it smells burnt, then it's not a bad idea to change it. Even if it seems ok, it's not a bad idea to change it anyway, as it allows you to establish a starting point for future changes.
Old Mar 8, 2005 | 11:52 AM
Johns9163's Avatar
Johns9163
I have always changed the fluid every 30K miles and have never had a problem. I have over 109,000 miles now. I also use synthetic. When I drop the pan, it is always clean!
Old Mar 8, 2005 | 10:22 PM
ET1's Avatar
ET1
I have a 4.2 and the recommended transmission oil is Mercon V. I brought my truck for an oil change to the dealer and I noticed that the oil they used is not Mercon V but a synthetic one. I asked them if they placed the correct oil and they said yes. Would I trust them?
