field wheeling?
Dustin
Bad things happen when STRAPS break because they s-t-r-e-t-c-h and will fly back at you when they break at incredible speeds. The BIG danger is when you have a clevis or some other metal chunk attached to the end of the strap (or in the middle like when people attach 2 together end to end). If something lets loose it can send that clevis flying fast enough to kill.
Chains do not stretch. When a chain breaks it falls to the ground and doesn't go flying through the air. They're a MUCH safer way to go. We weren't hearing about people's heads being crushed until the nylon straps became popular. The advantage to the straps is they do have that stretch and they can actually increase the pull force but you need to take proper precautions to make sure you're safe.
If you use straps throw a blanket, jacket, etc. over the middle of it so if it snaps it'll stop at that object and not fly back at you. Try to avoid using 2 straps attached to each other. If you must then you need a blanket over the middle of each individual strap, not over the clevis you use to attach them.
Tow smart. Tow S-mart!
have you ever broken a chain? Personally, I have not. I would be curious to see what would happen. People claim that winch cable doesn't fly through the air, but I don't believe that. BTW, chain does stretch, just not any where near the ammount that nylon does.
However, I do agree that you should NOT attach tow straps like that.
Chains I will use Because straps are a joke They are for wussy wanna-be people They streach and land in your back seat- I use chains and chains only They are way safer
haI
More about chain. If you use the mundo logging chain its about the safest of the bunch. Only broken one once years ago and it just dropped to the ground like Ivan said. You still run the risk of a broken link rocketing off, but chances are very slim. The stuff I had probably wouldn't have even broke except it was some old logging chain that had been through hell and gone. The problem is, very few folks using chain are using the good stuff. The stuff they are using is the much more readily found lighter weight that also has a good deal more elasticity. I've seen these break and snap back hard enough to hit the tailgate...not with much force mind you since the weight of the chain is still forcing it downwards, but still. With this stuff you do run a real risk of flying links. I'd rather see guys running nylon than cheap chain. Yes, even the best stuff you can buy at Ace or Home Depot is still cheap chain. Remember, chain isn't designed to be shockloaded, and unless you get the serious stuff it can and will break.
Ivan covered this all pretty well, I just thought I'd expand on the chain/cable aspect of it having used it all. Besides, can you trust a guy who doesn't have a front driveline in his 4x4?
but chain is still the best way to go
ivan chain does stretch
have fun can't wait to see the pics
... so far i have pulled myself out a couple of times, a few full sizes, numerous compacts, and even my 4x4 tractor when the front tires were buried.DO NOT use light gauge chain to ****** and DO NOT ****** with small straps. use common sense and make everyone stand back. don't forget the blanket to drape across the chain/strap
-cutts-
Personally, my preferred method of extraction is a heavy chain with a steady pull from a skidder/cat, or if you have to be snatched use one heavy nylon strap connected to the vehicles by a hard mounted heavy clevis on either end. Nothing on the ends of the straps, no hooks.
Things to think about before you do some XTREME! field wheeling.
Down here in Florida, there usually isn't any equipment handy, so we have to use trucks for extraction. I have an 8" clevis I loop over my receiver mount (not the slide in hitch) and attach one strap to that. On the other end of the strap, I take 1/2" grade 70 chain and loop around each side of the frame. Then drop each end of the chain through the strap loop, and hook it back to itself (sounds complex but really isn't). All the stress is then concentrated on 2 sections of chain, the strap loops and the 4 bolts that mount my hitch to the frame. No real potential for projectiles. We often also loop a strap around a reese mount and then clevis it shut. This forces the stress to be on two loops of strap material and not the clevis pin. Over the years we have broken some of just about everything, cheap chain, straps, frame horns, bumper mounts, and once even sheared a ball shank. The best thing to do is use common sense, buy the best recovery equipment you can afford, and keep everyone far away from the recovery attempt. And, most importantly, have a sober person attempt to pull the guy out.
Ernie
But for towropes, the only ones we use on the farm are the big suckers (we have a 10" double ply, frickin huge), and we always use a clevis is possible, or a chainstrapped around an axle with a clevis and the tow rope hooked to the clevis. The best times to use a rope is when your vehicle is smaller or the same size as the stuck vehicle (in my expierence on the farm), as often times you need the multiplication in pulling force to pop them out (again simple high school physics will show this) but it varies from stuck to stuck.
Always drap an old blanket or something over the middle of the rope or chain, as if a chain is going to break its generally going to be in middle, and a coat or blanket can help prevent this, ever seen a broken link break a camper window (pulling a 2wd tractor out and the chain snapped in the middle and unfortunately an old beater truck was close enough to get hit)?
(For the unexperienced)- Doesnt have to be a blanket, coat, towel or anything... You can use anything that is decent in weight like another chain or your little brother or something.
Also, If youre going to use a towel, dip it in water first, it will be a lot more effective than a dry one in hte rare event (yet not so rare) that the chain/tow strap breaking...
