Where's my coolant?
Old Mar 7, 2005 | 08:55 PM
vicv's Avatar
vicv
Where's my coolant?
Hi All, have a 97 XLT 180k miles. Got CEL light indicating O2 sensors so I replaced them. Started smoking/stinking and smeling like coolant. I tightened the intake manifold bolts and replaced a contaminated, but not too old, O2 sensor. Worked for 2 weeks then started smoking/smelling again. Replaced both intake manifold gaskets, air cleaner, seafoam in the gas, oil change. No CEL for 1 day then it came back on. Running like crap but I can't see any coolant leaks or smell anything in the exhaust. I yank the plugs and one of them is missing the ceramic electrode, busted off halfway up the plug! Replaced the plugs and it runs better but still a tad on the rough side. Also noticed that the coolant overflow tank is now empty. Should I keep the air cleaner and put a motor around it? All suggestions are greatly appreciated.
Thanks, Vic
Old Mar 8, 2005 | 06:01 AM
marragtop's Avatar
marragtop
Any sign of a blown head gasket, such as water in the oil? With the engine cold, take off the radiator cap and give it some RPMS. If water starts gushing out of the radiator, you may have a blown head gasket. Did it ever overheat? Also, if you only current problem is with how it runs, you might want to replace the wires and look for vacuum leaks.
Old Mar 9, 2005 | 06:32 AM
vicv's Avatar
vicv
Thanks, Marragtop. No signs of water in the oil, never overheated since I've owned it (5 yrs). Has been good up to this point. I'll double check vac lines for cracks, could have broken one when intake gaskets replaced. Wires are 4 yrs old, might have to replace them too.
Gil Chesterton
23
Mar 16, 2020 09:35 PM
SHOpar
1983 - 2012 Ranger & B-Series
Jan 22, 2015 11:26 PM
dz1
Sep 27, 2012 05:07 PM
87wreckerman
Modular V8 (4.6L, 5.4L)
Nov 4, 2007 10:34 PM
chelmer
41
Apr 21, 2006 02:25 PM
